hm_getsolverid2
Returns the solver ID and pool name for the specified HyperMesh internal ID.
hm_getsolverid2 entity_type entity_name_or_id ?search_type?
HyperMesh Tcl Query Command
Returns the solver ID and pool name for the specified HyperMesh internal ID. If there is no solver ID and pool for the specified entity, the internal ID and a blank ID pool are returned.
- entity_type
- The type of entity to query.
- entity_name_or_id
- The internal ID or name of the entity to query.
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
Examples
To get the solver ID and pool name for property with internal ID 4:
hm_getsolverid2 props 4
or
hm_getsolverid2 props 4 -byid
To get the solver ID and pool name for a material with name 1:
hm_getsolverid2 mats 1
or
hm_getsolverid2 mats 1 -byname
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
