hm_getoccupiedentitiesinrange
Returns the list of occupied IDs in a specific range.
hm_getoccupiedentitiesinrange entity_type pool_id range
HyperWorks Tcl Query Command
Returns the list of occupied IDs in a specific range. The values are returned as a compacted list using ranges and commas where applicable.
- entity_type
- The type of entity to query.
- pool_id
- The ID of the entity pool to query.
- range
- The ID range within the specified pool to query. This should be encapsulated in quotes.
To get the element IDs in use in pool 2 for the range 100-200:
hm_getoccupiedentitiesinrange elems 2 "100-200"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
