hm_wadlinessetwipers
Sets the wiper entities for a WAD lines analysis.
hm_wadlinessetwipers entity_type mark_id use_for_reference_line use_for_wad_line
HyperMesh Tcl Query Command
Sets the wiper entities used for a WAD lines analysis.
- entity_type
- The entity type denoting the wipers. Valid values are elems, surfs and comps (elems take priority over surfs).
- mark_id
- The ID of the mark containing the wiper entities. Valid values are 1 and 2.
- use_for_reference_line
- 0 - Off
- use_for_wad_line
- 0 - Off
To setup and extract WAD lines data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
*createmark elems 1 "by collector" wipers
hm_wadlinessetwipers elems 1 0 1
hm_wadlinesgetreferenceline 0
hm_wadlinesgetreferenceline 1
hm_wadlinesgetreferenceline 2
hm_wadlinesgetreferenceline 3
hm_wadlinesgetreferenceline 4
hm_wadlinesgetreferenceline 5
hm_wadlinesgetreferenceline 6
hm_wadlinesgetreferenceline 7
hm_wadlinesgetwadline 1000.0
hm_wadlinesgetwadline 1500.0
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadline 2100.0
hm_wadlinesgetgridpoints 1000.0 1500.0 1700.0 2100.0 50.0
hm_wadlinesend
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}None.
Version History
13.0
