hm_getdeleteassociatedentitiesbycompmark
Returns the unique associated entities for the components on a mark.
hm_getdeleteassociatedentitiesbycompmark input_mark_id output_mark_id
HyperMesh Tcl Query Command
Returns the unique associated entities for the components on a mark. The associated entities are returned for each selected component, as well as added to the output mark.
The return value is a "list of lists". Each list contains the following:
{component ID {entity type {entity IDs...}}}
For example:
{2 {comps 2}} {2 {loads {1 2 3 4 5 6 7 8 9 10}}} {2 {sets {1 2 3 4}}} {2 {props 1}} {2 {mats 2}} {3 {comps 3}} {3 {loads {1 2 3 4}}} {3 {sets {1 2 3 4}}} {3 {props 2}} {3 {mats 2}}
- input_mark_id
- The ID of the mark containing the input components. Valid values are 1 and 2.
- output_mark_id
- The ID of the mark containing the output entities. Valid values are 1 and 2.
To get the associated entities for component 4 on mark 1:
*createmark comps 1 4
hm_getdeleteassociatedentitiesbycompmark 1 2
{4 {comps 4}} {4 {loads {325 326}}} {4 {loadcols 2}}
hm_getmarkall 2
{nodes 7 8 9 10 11} {comps 4} {loads 325 326} {loadcols 2}
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
