hm_morph_getmvoledgenodes
Returns the IDs of the nodes along a specified morph volume edge.
hm_morph_getmvoledgenodes edge_id
HyperMesh Tcl Query Command
- edge_id
- The ID of the morph volume edge.
To find the node IDs for morph volume edge 5:
hm_morph_getmvoledgenodes 5
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0.110
