hm_marklength
Returns the number of entities on the specified mark.
hm_marklength entity_type mark_id
HyperMesh Tcl Query Command
This command returns the number of entities on the specified mark.
- entity_type
- The type of entity mark to query.
- mark_id
- The ID of the mark. Valid values are 1 and 2.
To count the components on mark 2:
hm_marklength comps 2
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023 - Deprecated argument panel_sensitive.
