hm_modent_getentityparent
Returns the hierarchical modular entity parent of a specific entity.
hm_modent_getentityparent entity_type entity_id parent_entity_type
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- entity_id
- The ID of the entity to query.
- parent_entity_type
- The type of parent entity to query. Valid values are subsystemconfigurations, subsystems, and subsystemsets.
Examples
To return the parent subsystem of component 1000:
hm_modent_getentityparent comps 1000 subsystems
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
