hm_attributelistall
Returns a list of all attribute IDs, names, types or type names for the current template.
hm_attributelistall value
HyperMesh Tcl Query Command
- value
- The type of list to return. Valid values are:
Examples
To list the IDs of all the attributes in the current template:
hm_attributelistall id
To list the names of all the attributes in the current template:
hm_attributelistall name
To list the type number of all the attributes in the current template:
hm_attributelistall type
To list the type name of all the attributes in the current template:
hm_attributelistall typename
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10-SA1-110
