hm_wadlinessethood
Sets the entities for the hood used to create the reference line.
hm_wadlinessethood entity_type mark_id
HyperMesh Tcl Query Command
This API must be used after initializing the wadlines analysis using hm_wadlinesinit.
- entity_type
- The type of entities being set for the hood. Valid values are comps, surfs and elems.
- mark_id
- The ID of the mark containing the hood entities. Valid values are 1 and 2.
Examples
To set the hood entities to comps 102 and 103:
*createmark comps 1 102 103
hm_wadlinessethood comps 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
