hm_jobs_getServerDetails
Returns the name, IP and port of a server.
hm_jobs_getServerDetails name
HyperMesh Tcl Query Command
Returns the name, IP and port of a server. If the server does not exist, nothing is returned.
- name
- The name of the server to query.
To query the server named HWUL:
hm_jobs_getServerDetails HWUL
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
