hm_getedgeloops2
Returns surface and element boundary entities of specific connection types, and assumes any non-selected entities do not exist.
hm_getedgeloops2 entity_type markid=<mark_id> ?looptype=<loop_type>?
HyperMesh Tcl Query Command
Returns the chain of boundary entities of the given type. The return is a "list of loops". Each loop is an ordered list of either surface edge or element node IDs that define each loop. The first value in each loop list is the loop type. For example, a list that starts with number 32 means the list consists of entities (nodes or edges) representing an x-connection type ‘closed’ loop. The remaining values are the ordered node/surface edge IDs defining the loop. If the loop is closed, the first and last ID are the same.
This API is similar to hm_getedgeloops. The difference is that, in defining the connection types at the boundary, hm_getedgeloops takes into account all the elements/surfaces in the model, while hm_getedgeloops2 considers only the given input as if the rest of the model does not exists. Thus, if the edge of a surface is connected to another surface that is not in the input, then that edge is considered to be a ‘free’ edge; that is, as if it is not stitched to any other edge. In this sense, the boundary entities (nodes or edges) of input entities are classified according to their connection type of being ‘free’, ‘t-connection’ or ‘x-connection’.
For example:
{2 41 36 4 35 39 40 41} closed loop of free type entities
{4 42 67} open loop of t-connection type entities
- entity_type
- The type of entity to query. Valid values are surfaces and elements.
- markid=<mark_id>
- The ID of the mark containing the entities to query. Valid values are 1 and 2.
- looptype=<loop_type>
- The type of loop types to find. Bit values are used and the value is calculated as
(1*Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3 + 16*Bit4 + 32*Bit5). If not specified, all loop
types are returned.
- Bit0
- 0 - Do not consider open free edge loops
- Bit1
- 0 - Do not consider closed free edge loops
- Bit2
- 0 - Do not consider open t-connections
- Bit3
- 0 - Do not consider closed t-connections
- Bit4
- 0 - Do not consider open x-connections
- Bit5
- 0 - Do not consider closed x-connections
Examples
*createmark surfs 1 displayed
hm_getedgeloops2 surfs markid=1*createmark surfs 1 displayed
hm_getedgeloops2 surfs markid=1 looptype=12*createmark elems 1 displayed
hm_getedgeloops2 elems markid=1 looptype=2*createmark surfs 1 4 6 8 9
hm_getedgeloops2 surfs markid=1 looptype=16Errors
# Handle error
}Version History
2020.1
