hm_getsolidmappablestate
Returns the mappable state of the specified solid.
hm_getsolidmappablestate solid_id
HyperMesh Tcl Query Command
Returns the mappable state of the specified solid. The following values can be returned:
- -1 - Not evaluated for mappability
- 0 - Unmappable
- 1 - 1-direction mappable
- 3 - 3-direction mappable
- solid_id
- The ID of the solid geometry to query.
To get the mappable state of solid
10:
hm_getsolidmappablestate 10Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.102
