hm_jobs_editServer
Edits an already existing server.
hm_jobs_editServer name new_name new_host new_port
HyperMesh Tcl Query Command
Note that the "local" server is not editable.
- name
- The name of the server to edit.
- new_name
- The new name of the server.
- new_host
- The new host/IP of the server.
- new_port
- The new port number on which the server will communicate.
To edit the server HWUL:
hm_jobs_editServer HWUL hwul 172.1.3.4 17084
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
