hm_exportdummytargetpointstocsv
Exports the marked design points with ‘TargetPoint’ configuration to a CSV file.
hm_exportdummytargetpointstocsv mark_id file_path
HyperMesh Tcl Query Command
Exports design points in the model with 'TargetPoint' configuration to a comma
separated values (CSV) file. The following fields will be written in the CSV file:
- the name of the design point,
- X/Y/Z,
- the corresponding test lab measurement data,
- the allowed negative deviation,
- the allowed positive deviation,
- the coordinate value for the measurement node located on the dummy,
- the signed difference between the CAE position and the test data.
If the specified CSV file already exists, it will be overwritten.
- mark_id
- The ID of the mark containing the design points to be exported. Valid values are 1 and 2.
- file_path
- The path to the CSV file.
To export design points ID 1, 2, and 3 to a file named
targetpoints.csv located in the
C:/temp directory:
*createmark designpoints 1 1 2 3
hm_exportdummytargetpointstocsv 1 "C:/temp/targetpoints.csv" Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
