hm_jobs_startService
To explicitly start the PBS-sensor services.
HyperMesh Tcl Query Command
This command is used to explicitly start the PBS-sensor services. Any of the actions related to server go through PBS-sensor services. By default, PBS-sensor is started implicitly when any job related API is being used. In special cases this can be used to invoke the PBS-sensor services.
Examples
To invoke PBS-sensor services explicitly:
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
