hm_ce_getresolvedlinkentities
Returns resolved link entity information.
hm_ce_getresolvedlinkentities ce_id link_entity_type
HyperMesh Tcl Query Command
Returns the link information for the resolved entities organized per link-index. The output will contain the entity ID if the link-entity is present in current model else it will be 0.
- ce_id
- The ID of the connector to query.
- link_entity_type
- The link entity type to query.
Examples
For connector ID 7 with link 1 as component_1, link 2 as component_2, and both components
exist in the model:
hm_ce_getresolvedlinkentities 7 comps;
output: 1 2
hm_ce_getresolvedlinkentities 7 parts;
output: 0 0For connector ID 7 with link 1 as component_1, link 2 as component_2, and only component_1
exists in the model:
output: 1 0
output: 0 0For connector ID 7 with link 1 as {component_1 component_2}, link 2 as component_3, and
only component_1 and component_3 exist in the
model:
output: {1 0} 2
output: {0 0} 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
