hm_getsourcecompsgroupsusingprefixbasenamesuffix
Returns a list of matching component IDs which have the same prefix-base-suffix name in the original model and an incoming model.
HyperMesh Tcl Query Command
None
Examples
For components that are matching as shown below (ID in brackets):
abc-comp1-123.1234 (1) abc-comp1-123-4.5678 (4)
xyz-comp2-345.123 (2) xyz-comp2-345.789 (3)
{1 4 2 3}
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
