hm_fe_getdvstfile
Returns the dvst file set for weld or property creation.
hm_fe_getdvstfile ce_id
HyperMesh Tcl Query Command
This command returns the diameter versus thickness file set on a connector.
- ce_id
- The ID of the connector.
To get the diameter versus thickness file for connector with ID
1:
hm_fe_getdvstfile 1Errors
None.
Version History
2024 - Added new input ce_id.
