hm_getidpoolnumber
Returns the ID pool number for a given solver and ID pool name.
hm_getidpoolnumber solver_id pool_name
HyperMesh Tcl Query Command
- solver_id
- The solver template ID. If set to 0 the current template is used.
- pool_name
- The solver pool name to query.
To get pool number of LS-DYNA element ID pool ELEMENT_SOLID_IDPOOL:
hm_getidpoolnumber 9 ELEMENT_SOLID_IDPOOL
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
