hm_wadlinesgetwadpointtapeline
Returns coordinate data defining a line made by the measuring tape running from the ground to the specified WAD point along the vehicle.
hm_wadlinesgetwadpointtapeline lateral_location distance
HyperMesh Tcl Query Command
Returns coordinate data defining a line made by the measuring tape running from the ground to the specified WAD point along the vehicle. The data will be returned as a list of doubles. Every three doubles are the X, Y, and Z coordinates of a point along the line. The line runs from the ground to the specified WAD point.
- lateral_location
- The lateral location for the tape line, using the centerline of the vehicle as the origin. The location given must be a multiple of the spacing parameter set with hm_wadlinessetparameters. For example, if the value of spacing is 100.0, the values of the lateral_location must be 0.0, 100.0, -100.0, 200.0, -200.0, 300.0, etc...
- distance
- The distance from ground level to a WAD point, as measured along the vehicle.
Examples
To setup and extract WAD point tape line data:
hm_wadlinesinit
hm_wadlinessetparameters 45.0 50.0 100.0 100.0 50.0 20.0 25.0 60.0
hm_wadlinessetaxes 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0
*createmark comps 1 "bonnet" "bumper" "fenderL" "fenderR"
*createmark comps 2 "windshield" "a-pillars"
hm_wadlinessetentities comps 1 comps 2
hm_wadlinesgetwadline 1700.0
hm_wadlinesgetwadpointtapeline -700.0 1700.0
hm_wadlinesgetwadpointtapeline -600.0 1700.0
hm_wadlinesgetwadpointtapeline -500.0 1700.0
hm_wadlinesgetwadpointtapeline -400.0 1700.0
hm_wadlinesgetwadpointtapeline -300.0 1700.0
hm_wadlinesgetwadpointtapeline -200.0 1700.0
hm_wadlinesgetwadpointtapeline -100.0 1700.0
hm_wadlinesgetwadpointtapeline 0.0 1700.0
hm_wadlinesgetwadpointtapeline 100.0 1700.0
hm_wadlinesgetwadpointtapeline 200.0 1700.0
hm_wadlinesgetwadpointtapeline 300.0 1700.0
hm_wadlinesgetwadpointtapeline 400.0 1700.0
hm_wadlinesgetwadpointtapeline 500.0 1700.0
hm_wadlinesgetwadpointtapeline 600.0 1700.0
hm_wadlinesgetwadpointtapeline 700.0 1700.0
hm_wadlinesendErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
