hm_exportidmgr
Exports the ID manager rules to a CSV or XML file.
hm_exportidmgr filename format
HyperMesh Tcl Query Command
- filename
- The full name and path of the file to export.
- format
- 0 - CSV
To output the rules to C:/temp/rules.csv:
hm_exportidmgr C:/temp/rules.csv 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.120
