*loaddefaultattributevaluesfromxml
Loads the entity's default setting values in the specified XML file.
*loaddefaultattributevaluesfromxml ?xmlfilename?
HyperMesh Tcl Modify Command
Loads the entity's default setting values, mandatory values, show/hide values, and so on, that are defined in the specified XML file. If the file name is not specified, it unloads the previously loaded default settings.
- xmlfilename
- The XML file path containing the entity default settings.
Examples
To load the default values specified in the EntityDefaults.xml
file:
*loaddefaultattributevaluesfromxml D:/settingsfile/EntityDefaults.xmlTo unload the previously loaded default
values:
*loaddefaultattributevaluesfromxmlErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
