*exclusiveidrange
Sets an exclusive ID range.
*exclusiveidrange submodel_type id shortname entity_type ?pool_id?
HyperMesh Tcl Modify Command
This command sets an exclusive ID range for a submodel.
- submodel_type
- The submodel type to sets the exclusive ID range for. Valid values are includes and includefiles.
- id
- The submodel ID. Not required, if shortname is used.
- shortname
- The shortname of the submodel. Not required if id is used.
- entity_type
- The entity type to set the exclusive ID range for.
- pool_id
- The optional ID of the solver pool.
To set an exclusive component ID range for include
1:
*exclusiveidrange includes 1 "" compsErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
2019 - Added new optional argument pool_id.
