*deleteidrange
Deletes an ID range.
*deleteidrange submodel_type id shortname entity_type ?pool_id?
HyperMesh Tcl Modify Command
This command deletes an ID range for a submodel.
- submodel_type
- The type of submodel to delete the ID range for. Valid values are includes and includefiles.
- id
- The ID of the submodel. Not required if shortname is used.
- shortname
- The shortname of the submodel. Not required if id is used.
- entity_type
- The type of entity to delete the ID range for.
- pool_id
- The optional ID of the solver pool.
Examples
To delete an ID range for include 1 for
components
*createidrange includes 1 "" compsErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
2019 - Added new optional argument pool_id.
