*clearlock
Clears all entity locks.
*clearlock entity_type dataname
HyperMesh Tcl Modify Command
This command clears all entity locks for a specified entity type.
- entity_type
- The type of entity to clear locks for.
- dataname
- The dataname to clear locks for. Currently only supported for "ID".
Examples
To clear ID locks for all elements:
*clearlock elems idErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
