*AE_AttachmentAbsorb
Absorb FE into attachments.
*AE_AttachmentAbsorb entity_type integer_array number_of_integers option config
HyperMesh Tcl Modify Command
- entity_type
- The entity type to absorb. Valid values are nodes and elements.
- integer_array
- The ID of the integer array created using *createarray, which contains the IDs of the entities to absorb. Must be set to 1. If the array is empty, all rigidlink, RBE2 and RBE3 elements are considered.
- number_of_integers
- The number of integers in the array. If 0, all elements are considered.
- option
- A flag to specify if the absorption logic should consider selected entities or all elements:
- config
- The config for the attachment:
Examples
Absorb an attachment from elements 116 and 227 (RBE2
types):
*createarray 2 116 227
*AE_AttachmentAbsorb elements 1 2 0 1Absorb an attachment from all the rigidlink, RBE2 and RBE3
elements:
*AE_AttachmentAbsorb elements 1 0 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
