*createfmvss201u_end
Closes and deletes all the temporary entities created during upper interior marking of a vehicle.
*createfmvss201u_end ?deleteentities=<value>?
HyperMesh Tcl Modify Command
This command deletes all the temporary entities created during upper interior marking of a vehicle. To be called after *createfmvss201u_start and *createfmvss201u_createpoints commands.
- deleteentities=<value>
- 1 – Deletes temporary entities created during marking.
Examples
To mark all types of design points at once:
*createfmvss201u_endErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
