*midsurface_extract_10
Extracts mid-surfaces from a selection of surfaces or solids.
*midsurface_extract_10 entity_type mark_id outbound_normals thickness_bound align_steps extract_by_comp rerun_type stitch_tol_mode max_R_t_ratio reserved_1 reserved_2 max_thickness_ratio min_thickness max_thickness mid_position reserved_3 reserved_4 reserved_5 new_or_curr_comp
HyperMesh Tcl Modify Command
This command extracts mid-surfaces from a selection of surfaces or solids.
- entity_type
- The type of entity selected for mid-surface extraction. Valid values are surfaces and solids.
- mark_id
- The ID of the mark containing the input entities.
- outbound_normals
- If entity_type is surfaces:
- -1 - If surfaces selected on mark_id form a closed solid (but entity_type parameter is not set to solid). In this case the surfaces will be re-oriented, if needed, to have the normals go outside the solid they form.
- 0 - If the normals go inside the selected surfaces.
- 1 - If the normals go outside the selected surfaces.
- thickness_bound
- Limits on midsurface thickness:
- align_steps
- Determines how steps are aligned for solids with discrete sections. This parameter also determines whether any specified base surfaces are taken into account when constructing the middle surface. If the values are 0, 1, or 2, the base surfaces are not used. In order to take the base surfaces into account, the value should be increased by 3.
- extract_by_comp
- 0 - Extraction of the mid-surfaces can occur between any matching pair of the surfaces.
- rerun_type
- Used to specify one of the mid-surface extraction methods: offset, offset+planes, offset+planes+sweeps or skin offset.
- stitch_tol_mode
- Defines the mode for performing mid-surface stitching. Valid values are:
- max_R_t_ratio
- This is a ratio between the fillet radius and plate thickness analyzed at T, X and similar junctions. If the calculated ratio is greater than this parameter, the fillet does not collapse. In previous releases the ratio was a default value of 2 and could not be changed.
- reserved_1
- Reserved for future development. Value = 0.
- reserved_2
- max_thickness_ratio
- This is a ratio between a plate thickness found during the midsurfacing and the minimum plate thickness found during the midsurfacing. If the ratio is exceeded the corresponding midsurface will be ignored. The parameter is used when thickness_bound is 0. It can be any real number > 1.
- min_thickness
- Sets the minimum plate thickness bound. This parameter is used when thickness_bound is 1. It can be any real number ≥ 0.
- max_thickness
- Sets the maximum plate thickness bound. This parameter is used when thickness_bound is 1. It can be any real number > min_thickness.
- mid_position
- Sets the midsurface position for step alignment case when align_steps is set to 2. This can be any number between 0 and 1.
- reserved_3
- Reserved for future development. Value = undefined.
- reserved_4
- reserved_5
- new_or_curr_comp
- 1 - Midsurface will be created in a new component named "Middle Surface".
To extract the midsurface of solids ID 5 through 7, no thickness bounds, align the steps at 0.39, only extract surfaces between the same component, max thickness ratio of 10, and organize them into the "Middle Surface" component:
*createmark solids 1 5 6 7
*midsurface_extract_10 solids 1 3 0 2 1 0 0 2 10 0 0 0.39 undefined 0 0 1
# Handle error
}Version History
10.0
2020 - Added new value 100 to extract_by_comp.
2024 - Added new new_or_curr_comp values 3, 6, 7, 16, 17, and 20 and removed new_or_curr_comp values 0, -1, -2, -3, -4, and -5.
