*systemcommand
Executes a system command.
*systemcommand command
HyperMesh Tcl Modify Command
This is also possible via standard Tcl functionality.
- command
- The system command to execute.
To execute the command ABC and redirect it to the file
DEF:
*systemcommand "ABC>DEF"Errors
None.
