*clearlock2
Clears all entity locks.
*clearlock2 entity_type pool_id dataname
HyperMesh Tcl Modify Command
- entity_type
- The entity type to clear locks for.
- pool_id
- The solver pool ID.
- dataname
- Must be set to id.
Examples
To clear locks for all elements:
*clearlock2 elems 0 id
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
