*midsurface_set_not_a_plate_side
Assigns the given set of surfaces a non-plate type.
*midsurface_set_not_a_plate_side mark_id use_base_surfaces functionality
HyperMesh Tcl Modify Command
This command changes the plate information for every surface on the input mark. The command
can be used to set the surfaces to be:
- Plate edge (known as "not a plate side" in 12.0)
- Transition surface
- Not a trim surface
If the base surface information is to be taken into account, the command will also do a
preliminary check whether the given set of surfaces includes any base surfaces or not. If
there is any base surface present, the command will exit without doing anything.
Note: Base
surfaces can only be parts of offset plates. They cannot be a part of planar plates, sweep
plates, plate edges, transitions, or not-a-trim surfaces.
- mark_id
- The ID of the mark containing the input surfaces. Valid values are 1 and 2.
- use_base_surfaces
- This specifies whether the user-defined base surfaces will be taken into account or not to specify the surface type. Valid values are:
- functionality
- Specifies what non-plate are the surfaces in the input mark turned into:
To set the surfaces with IDs 5 through 7 to be transition surfaces, including a check for the input mark to contain base surfaces:
*createmark surfaces 1 5 6 7
*midsurface_set_not_a_plate_side 1 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
