*hf_setdieline
Sets the selected lines as TL or POL.
*hf_setdieline entity_type mark_id flag
HyperMesh Tcl Modify Command
This command sets the selected lines as TL or POL.
- entity_type
- Must be set to lines.
- mark_id
- The mark ID containing the lines of interest. Valid values are 1 and 2.
- flag
- 0 - Set as TL.
To set line 15 as
POL:
*createmark lines 1 15
*hf_setdieline lines 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
