*createcirclecenterpoint
Creates a point at the center of a circle defined by 3 input points.
*createcirclecenterpoint point_id1 point_id2 point_id3
HyperMesh Tcl Modify Command
- point_id1
- The ID of the first point defining the circle.
- point_id2
- The ID of the second point defining the circle.
- point_id3
- The ID of the third point defining the circle.
Examples
To create a point at the center of the circle defined by points 100, 200 and
300:
*createcirclecenterpoint 100 200 300Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
