*setelemqualityparamactive
Sets the on/off state for a specified element quality parameter.
*setelemqualityparamactive param_id activ
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the on/off state for a specified element quality parameter.
- param_id
- Specifies the element quality check parameter ID to update. Valid values are:
- 0 - min size
- 1 - max size
- 2 - aspect ratio
- 3 - warpage
- 4 - max interior angle quad
- 5 - min interior angle quad
- 6 - max interior angle tria
- 7 - min interior angle tria
- 8 - skew
- 9 - Jacobian
- 10 - chordal deviation
- active
- 0 - Inactive/off
- 1 - Active/on
Examples
To activate "warpage" parameter:
*setelemqualityparamactive 3 1
To disable "Jacobian" parameter:
*setelemqualityparamactive 9 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
