*masknotshown
Masks all supported entities not in the current view window.
*masknotshown
HyperMesh Tcl Modify Command
Masks all supported entities not in the current view window. For collected entities, only
entities in displayed collectors are affected. This includes:
- points
- lines
- surfaces
- solids
- elements (both in components and groups)
- connectors
- loads
- equations
- systems
- vectors
- tags
- domains
- handles
- morphconstraints
- morphvolumes
- shapes
- symmetries
To mask all supported entities in the displayed collectors that are not in the current view
window
*masknotshown:Errors
None.
