*createcirclefrompoints
Creates a circle or arc from 3 nodes.
*createcirclefrompoints list_id circle_flag
HyperMesh Tcl Modify Command
This command creates a circle or arc from 3 nodes.
- list_id
- The ID of the list containing the nodes that define the circle. The order of the nodes is important if creating an arc.
- cirlce_flag
- 1 - Create a circle.
Examples
To create a circle through nodes 100, 200 and
300:
*createlist nodes 1 100 200 300
*createcirclefrompoints 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
