*elementqualityoptimizeelementnew
Optimizes 2D element node locations to improve the element and adjacent elements' quality index according to pre-set quality criteria.
*elementqualityoptimizeelementnew element_id midnodes_flag
HyperMesh Tcl Modify Command
This command optimizes 2D element node locations to improve the element and adjacent elements' quality index according to pre-set quality criteria.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- element_id
- The element ID.
- midnodes_flag
- 0 - Do not consider neighboring mid-nodes during optimization.
To optimize the node locations of the elements with IDs 397, 432 and 102 using quality
criteria from a
file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityoptimizeelementnew 397 1
*elementqualityoptimizeelementnew 432 0
*elementqualityoptimizeelementnew 102 1
*elementqualityshutdown 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
