*ME_ModulesHierarchyLibrarySync
Finds library related information for a part from a connected part library and updates Part Browser.
*ME_ModulesHierarchyLibrarySync id options
HyperMesh Tcl Modify Command
Finds library related information for a part from a connected part library. Library related information such as Major Revision, Study Revision and Library Revision are then updated in Part Browser and Property Area.
- id
- The ID of the module/part for which information is needed.
- options
- The list of input options, passed as a comma separated string enclosed in quotes. Valid options are:
Update library related information for part 100 using library MyLibrary and updated
Area:
*ME_ModulesHierarchyLibrarySync 100 "updatesignal=1, libraryname=MyLibrary";Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019.1
