*freebodysectiondisplacementtable
Creates an FBD displacement summary table from freebodysection entity.
*freebodysectiondisplacementtable entity_ids subcase_ids string_array number_of_strings
HyperMesh Tcl Modify Command
Creates an FBD displacement summary table. This queries the GPF, Applied, SPC and MPC data from the result entity on a freebodysection.
- entity_ids
- The freebodysection entity IDs.
- subcase_ids
- The subcase details supplied as an array. Values are specified as <resultfile_id>_<subcase_id>_<step_id>, with each list separated by a comma.
- string_array
- The ID of the string array that contains the additional input parameters. The string
array is created using the *createstringarray command. This should
always be set to 1. Valid parameters and their syntax are:
- displacement=<value>
- 0 - Applied forces are not participating in the FBD calculation (default)
- freenode=<value>
- Currently must be set to 2. This is a mandatory argument.
- resolvein_sys=<value>
- 1 - Resolve in global system
- resultid=<value>
- The result entity ID.
- rotation=<value>
- 0 - SPC forces are not participating in the FBD calculation (default)
- tolerance=<value>
- The tolerance to limit the values. Default is 0.00001.
- user_sys_id=<value>
- The system ID when resolvein_sys=2.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To create an FBD displacement summary
table:
*createstringarray 8 "tolerance=0.00001" "resultid=1" "display=0" "resolvein_sys=1" "user_sys_id=0" "displacement=1" "rotation=1" "freenode=2"
*freebodysectiondisplacementtable {1 2 3} {2_1_0,2_2_0} 1 8Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2023
