*surfacesplineonnodesloop2
Creates a spline surface using a node list as boundary conditions.
*surfacesplineonnodesloop2 list_id options
HyperMesh Tcl Modify Command
- list_id
- The ID of the list containing the input nodes. Valid values are 1 and 2.
- options
- If set to 0, input nodes that were not already associated to any geometry get associated to the new surface. In addition, in simultaneous meshing modes set by *surfacemode, input nodes are taken into account to create connections between the new surface mesh and an already existing mesh.
To build a spline from the nodes 1, 2, 3 and 4:
*surfacemode 1
*createlist nodes 1 1 2 3 4
*surfacesplineonnodesloop2 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
