*morphmaptshpface
Adds a 2D domain perturbation to the current temporary shape.
*morphmaptshpface d_entity_type d_mark_id e_entity_type e_mark_id s_entity_type s_mark_id plane nproj c_vec clear sym con type
HyperMesh Tcl Modify Command
This command maps a 2D domain to a plane, a mark of surfaces, or a mark of elements either normal to the target or along a vector. When mapping to surfaces or a mesh the option to fit the domain to the entities is available.
This command is part of the map to geometry function which consists of multiple commands. This command may be called any number of times, first with clear set to 1, then subsequently set to 0, followed either by one of the many *morphmapto... commands. If clear is set to 2 then the last *morphmaptshpface command is rejected.
- d_entity_type
- Must be set to domains.
- d_entity_mark
- The ID of the mark containing the domains to be mapped. Valid values are 1 and 2.
- e_entity_type
- Must be set to elems.
- e_entity_mark
- The ID of the mark containing the elements to which the domains are mapped. Valid values are 1 and 2.
- s_entity_type
- Must be set to surfaces.
- s_entity_mark
- The ID of the mark containing the surfaces to which the domains are mapped. Valid values are 1 and 2.
- plane
- The ID of the plane created using *createplane to which the nodes will be projected. Must be set to 1.
- nproj
- 0 - Project along vector given by c_vec
- c_vec
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- clear
- Determine if/how to delete perturbations:
- sym
- 0 - Do not use symmetry
- co
- 1 - Use constraints
- type
- The type of target to be mapped to:
To map a 2D domain to a surface using the fitting option:
*createmark domains 2 10
*createmark elements 1
*createmark surfaces 1 3
*createplane 1 1 0 0 0 0 0
*createvector 1 1 0 0
*morphmaptshpface domains 2 elements 1 surfaces 1 1 3 1 1 0 1 3
# Handle error
}Version History
12.0.110
