*window_entitymark
Fits the view to the entities on the mark.
*window_entitymark entity_type mark_id
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to fit.
- mark_id
- The ID of the mark of entities to fit. Valid values are 1 and 2.
Examples
To fit the view to elements 1-10:
*createmark elems 1 1-10
*window_entitymark elems 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
