*fmvss201u_autoposition
Positions the headform to the impact points on the upper interior of a vehicle and exports the positions.
*fmvss201u_autoposition ?option1=<value1>? ?option2=<value2>? … ?optionN=<optionN>?
HyperMesh Tcl Modify Command
This command positions the headform to the impact points on the upper interior parts of a vehicle and then exports the positions. For correct export of the solver deck, the headform and the vehicle parts files should be imported as separate includes. The headform and the vehicle must be aligned to the global coordinate axes and vehicle front should be pointing in +X or -X direction.
Export is supported for Radioss, LS-DYNA and PAM-CRASH.
- designpointids={id1 id2 … idN}
- The list of IDs of the design points to be positioned.
- dpnamesfordirandincludes=<value>
- The Boolean value to select if the exported directories and files have the respective design point’s name or a generic incremental name.
- exportdpids={id1 id2 … idN}
- The IDs of the positioned design points to be exported.
- exportheadformids={id1 id2 … idN}
- The IDs of the headform components to be transformed in the exported files.
- exportpath=<value>
- The path of the directory where the export files need to be created.
- folderforeachdp=<value>
- The Boolean value defining if the directories are separated for each design point’s export file.
- foreheadpartsids={id1 id2 … idN}
- The list of forehead’s component IDs.
- headformfilepath=<value>
- The path to the solver file of the headform.
- headformpartsids ={id1 id2 … idN}
- The list of headform’s component IDs.
- headformsystemid=<value>
- The ID of the headform’s system.
- mainfilepath=<value>
- The path to the solver file of the main vehicle.
- method=<value>
- 0 - Try to position the headform automatically.
- offset=<value>
- The offset required between the impact point and the trim surface.
- outertrimpartsids={id1 id2 … idN}
- The list of component IDs which make up the interior trim of the vehicle.
- transformationtype=<value>
- The integer value to select the type of transformation on the head form.
Solver Value Type LS-DYNA 0 *NODE_TRANSFORM 1 *INCLUDE_TRANSFORM Radioss 0 /GRNOD 1 //SUBMODEL PAM-CRASH 0 TRSFM/ - vehicledir=<value>
- 1 - Vehicle forward direction is toward positive X axis.
- velocity=<value>
- The velocity with which the head form impacts the vehicle.
Examples
To position the headform on selected design
*fmvss201u_autoposition method=0 vehicledir=-1 velocity=0 offset=0 outertrimpartsids={10000,10004,10007,10008,10010,10011,10013} headformpartsids={8,10} foreheadpartsids={10} headformsystemid={1} designpointids={1,2,3,4,5,6,7,8,9,10}To export position files for selected design
*fmvss201u_autoposition method=2 dpnamesfordirandincludes=1 folderforeachdp=0 transformationtype=0 exportdpids={2,3,7,9} exportheadformids={8,10,3} mainfilepath=F:/uiimpact/data/fmvss201_u_model.rad headformfilepath=F:/uiimpact/data/FMH_2.rad exportpath=F:/uiimpact/outputErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
