*nodemarkclear
Deletes temporary nodes and preserved nodes.
*nodemarkclear node_mark=<mark_id> clearTempNodes=<value> clearPreservedNodes=<value>
HyperMesh Tcl Modify Command
The command removes temporary nodes if clearTempNodes is set to 1 and converts preserved nodes to regular nodes if clearPreservedNodes is set to 1. The preserved nodes which are not element nodes will simply be removed.
- node_mark=<mark_id>
- The ID of the mark containing the input nodes. Valid values are 1 and 2.
- clearTempNodes=<value>
- Option to remove temporary nodes. Valid values are 0 (off) and 1 (on).
- clearPreservedNodes=<value>
- Option to convert/remove preserved nodes. Valid values are 0 (off) and 1 (on).
Examples
To remove temporary nodes and convert/remove preserved nodes from ID range
1-67:
*createmark nodes 1 1-67
*nodemarkclear node_mark=1 clearTempNodes=1 clearPreservedNodes=1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
