*lockallentities
Lock all entities with the same entity type and ID pool across includes.
*lockallentities entity_type pool_id dataname
HyperMesh Tcl Modify Command
- entity_type
- The type of entity to lock.
- pool_id
- The ID of the solver pool.
- dataname
- Must be set to id.
Examples
Lock all elements with ID pool 2:
*lockallentities elems 2 id
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
