*maskreverse
Reverses the masking state of a specific entity type.
*maskreverse entity_type
HyperMesh Tcl Modify Command
Reverses the masking state of a specific entity type. For collected entities, only entities
in displayed collectors are affected. This includes:
- components (points, lines, surfaces, solids, elements, connectors)
- points
- lines
- surfaces
- solids
- elements (both in components and groups)
- connectors
- groups (elements)
- loadcols (loads)
- loads
- equations
- systemcols (systems)
- systems
- vectorcols (vectors)
- vectors
- tags
- domains
- handles
- morphconstraints
- morphvolumes
- shapes
- symmetries
To reverse the masking of all vectors in the displayed vector collectors:
*maskreverse vectorcols
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
