*surfacecreatespinnodeswithoffsetangle
Spins a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher.
*surfacecreatespinnodeswithoffsetangle nodelist rotplane start_angle end_angle
HyperMesh Tcl Modify Command
Spins a list of nodes to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a surface of revolution for the automesher to use under the mesh without surface option.
- nodelist
- The ID of the list of nodes to be spun.
- rotplane
- The axis about which to spin the lines made from nodes (plane normal is used as axis vector and the base point of the plane is used as the rotation center).
- start_angle
- Degrees value of initial rotation angle: lines made from selected nodes are rotated by this value before surface "sweeping" begins.
- end_angle
- Degrees value of final rotation angle: surface "sweeping" stops at this value.
To a line made through nodes 8, 9, 10 and 11 from 45 to 90 degrees about an axis given by the vector (1 2 3) with rotation center at point (4 5 6), creating a surface of revolution but not creating any elements on it:
*surfacemode 4
*createlist nodes 1 8 9 10 11
*createplane 1 1 2 3 4 5 6
*surfacecreatespinnodeswithoffsetangle 1 1 45 90
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
