*createlistpanel
Provides a widget to create an ordered list of entities for use in a subsequent command.
*createlistpanel entity_type list_id message
HyperMesh Tcl Modify Command
- entity_type
- The type of entities to put on the list. Valid values are:
- elems
- laminates
- lines
- nodes
- plies
- points
- solids
- surfs
- list_id
- The ID of the list to populate. Valid values are 1 and 2.
- message
- A string indicating a message to display in the message bar.
Examples
To create a line from a user specified list of
nodes:
*createlistpanel nodes 1 "Select nodes for the line:"
set node_list [ hm_getlist nodes 1 ];
if { ! [ Null node_list ] } {
*linecreatefromnodes 1 0 150 5 179
}Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
