*tabledeleterow
Deletes a row of data from a table.
*tabledeleterow name row_index
HyperMesh Tcl Modify Command
- name
- The name of the table to update.
- row_index
- The index of the row to delete. Tables are indexed starting from 1 (1 to n rows). If specified as 0, the last row in the table is deleted.
Examples
To delete the last row from table1, which has 11 rows:
*tabledeleterow table1 0
or
*tabledeleterow table1 11
To delete row 3 from table1:
*tabledeleterow table1 3
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
