*midsurface_remove_display_plate_sides
Deletes the two components that contain copies of the model surfaces belonging to two sides of a given plate.
*midsurface_remove_display_plate_sides plate_number reserved1 reserved2
HyperMesh Tcl Modify Command
- plate_number
- Specifies the plate number for which the plate side information is to be deleted.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
To delete the plate information for the plate with plate number 127:
*midsurface_remove_display_plate_sides 127 0 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
